Request for VLAN ID and PPPoE Credentials for Using Own Router
  • April 29, 2026
  • 1 resposta
  • 126 visualizações
Hi,
I would like to replace the MEO Smart Router with my own router and set up a direct connection, rather than using bridge mode.
Could you please advise how I can obtain the following information:
  • VLAN ID for the internet connection
  • PPPoE credentials (and how to get them)
  • Any additional settings needed to connect a third-party router directly to the ONT
Thank you.
Solução por ana_Paula
Hi ​@Mellow
MEO does not use PPoE. To use your own router, you must contact Technical Support on 16209 (check tariff) to request that bridge mode be enabled. Once enabled, simply connect your own router to port 4 on the Fibergateway.
1 resposta
  • April 29, 2026
Hi ​@Mellow
