Hi everyone,
I am  experiencing frequent internet connection drops with my MEO Fiber service over the past few weeks. The connection usually drops multiple times a day, and it takes a few minutes to reconnect each time. I have tried restarting my router and checking all cables;  but the issue exist.
Has anyone else faced a similar problem? What steps did you take to resolve it?
Any advice or suggestions would be greatly appreciated!
Thanks in advance for your help.
Best regards,😊
I recommend that you report the situation to technical support from Helplines MEO
Technical support - 213 580 144 (Cost of a call to the fixed network according to your plan.)
